It is currently Sun Aug 24, 2025 11:07 pm
 Post subject: Carbon fibre top repair.
PostPosted: Wed May 20, 2020 1:52 am
First name: Cas
Hi there,
I have an ovation with a carbon top in for repair. A couple of the braces have popped off the top and unfortunately somebody has already tried to re-glue them with what looks like gorilla glue. (Messy expanded stuff as visible squeeze out)
The questions is, what is the best bet for gluing spruce braces to the carbon top? Assuming I can clean off enough of the gorilla glue.
PostPosted: Wed May 20, 2020 9:55 am
Use epoxy. It may be hard to clean off the old glue, but if you don't get it off you're basically gluing to foam at this point.
PostPosted: Wed May 20, 2020 11:00 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Epoxy is what should and almost must be used. Cleaning off the other crap will be that hard part.
Brian
PostPosted: Wed May 20, 2020 11:50 am
Drop an anvil on it.
These users thanked the author Chris Pile for the post: Hesh (Fri May 22, 2020 6:06 am)
PostPosted: Thu May 21, 2020 8:29 am
First name: Cas
Thanks guys, I’ll crack on with the epoxy.
PostPosted: Thu May 21, 2020 7:40 pm
Online
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Might want to speak with someone who repairs these instruments before setting out on the task. No surprises.
Peter Havriluk
PostPosted: Fri May 22, 2020 6:08 am
Epoxy is what Ov*tion originally used. Many shops won't work on these hence some of the comments. We won't work on them either they were never manufactured to be serviceable.
